getTarea()
Get a tarea par value from the database.
Usage
tareaVal = acs.getTarea( par, path )
- par (string)
- The parameter name.
- path (string)
- Data base path of the par.
Return Value
- tareaVal (string)
- The parameter value.
The path should be valid.
The parameter in the data base must be a String.
nodeNic = ROOT + RS + 'NODAL_INITIAL_CONDITION'
funcX = acs.getTarea( par = "script", path = nodeNic + RS + 'x_velocity' )
