Interim Edit Tools
Use the Interim Edit tools to modify plates, base surfaces, and collapsed lines on the midsurface.
The modifications you make to the midsurface using the Interim Edit tools are not automatically applied. You must delete and re-extract the midsurface in the Auto Extraction subpanel to apply your modifications.
Edit Plates Subpanel
Use the Edit Plates subpanel to manually review and edit plates when the automatic detection of plates is not correct.
Plate information will only created upon extracting midsurface using the offset+planes+sweeps and offset+planes methods.
Any changes made to the midsurface using the plate edit tools will not be visible until you click update within the same panel, or after you extract the midsurface using the offset+planes+sweeps or offset+planes methods.
Table 1. Panel Options
Option Action
show edit/all Display plate edit inputs.
Review planar plates / sweep plates / offset plates Select a plate type to review.
planar/ sweep / offset / auto Select a plate type to edit.
Planar
Group of surfaces that have a planar surface inserted in between them. The inserted middle surface is a trimmed piece of planar surface. Planar plate's midsurfaces are trimmed using plate edges.
Sweep
Group of surfaces that have a sweep surface inserted between them.
Offset
Group of surfaces that have a non-planar surface inserted between them. Midsurface will be created from offsetting one of the side plates (green plate).
Auto
Group of surfaces that automatically have a midsurface inserted between them. An algorithm determines the plate type for the group of surfaces that has a midsurface inserted between them.
single surface selector: surfs Select a single surface from the modeling window.
plates on / plates off Turn the display of plates on and off.
non-plates on / non-plates off Turn the display of non-plates (transition and not trim surface) on and off.
new plate Replace the selected surface with a new plate. The new plate's type is determined by your selection in the drop-down menu on the left-hand side of the panel.
transition surface Transition surface provides more information to the algorithm regarding inserting surface where two regular plates are intersecting. An algorithm calculates how far intersecting plates can be extended based on the transition surface.
not a trim surface Move the selected surface that you do not want to be used in the midsurface extraction process into the component, ^Not a trim surface. HyperLife Weld Certification ignores the surfaces in the ^Not a trim surface component during the extraction process.
switch sides Each plate has two sides (blue and green) between which the midsurface is inserted. By default, HyperLife Weld Certification generates the midsurface by offsetting the green side of the plate.
If you are unsatisfied with the midsurface that was generated from the green side and want the midsurface to be offset from the blue side, click switch sides. HyperLife Weld Certification offsets the midsurface from the new green side, which was blue before using switch side.
plate edge Acts as a trimming surface for all plate types, and is used to trim inserted midsurfaces.
show related midsurfaces Only display the midsurface associated with a plate in the modeling window.
full plate selector: surfs Select the plate(s) you wish to edit in the modeling window.
merge plates Combine multiple plates into a single plate.
restore displayed comps Restore the display of the components, as they were before you entered the Plate Edit panel, after you exit the panel.
Table 2. Command Buttons
Button Action
update Delete the existing midsurface, and then create a new midsurface with the modified plate edit information. HyperLife Weld Certification updates the Model browser with the new plate edit information.
clear all Delete all of the plate information.
reject Reject the most recent plate edit operation.
return Return to the edit plates subpanel.
Edit Base Surfaces Subpanel
Use the Edit Base Surfaces subpanel to specify a distance from the base surfaces of multiple solids, that you wish to treat as if they were continuous, to generate separate-but-aligned midsurfaces for during extraction.
Option Action
use base surfaces Enable inputs which you can use to specify a distance from the base surfaces of solids, that you wish to treat as if they were continuous, to generate separate-but-aligned midsurfaces for during extraction.
If use base surfaces is disabled, new midsurfaces will not be generated at the specified distance from the selected base surfaces. The setup of the base surfaces that you modified will be retained for future use as long as you do not delete them.
surfs selector Select base surfaces to edit.
distance to base Specify a distance to create new midsurfaces from the selected base surfaces.
lock manipulator Specify a distance to create new midsurfaces from the selected base surfaces using the manipulator in the modeling window. When selected, the manipulator value cannot be modified.
add base Apply the modifications made to the selected base surfaces.
delete base Delete the modifications made to the selected base surfaces.
Edit Collapsed Lines Subpanel
Use the Edit Collapsed Lines subpanel to enable visualization settings to display point associations on the midsurface after extraction, and manually define lines and line chains to establish the linkage between points that should collapse to the same location.
Option Action
allow rerun If allow rerun is selected and the allow rerun switch is set to prepare for rerun, the lines that connect associated points on the midsurface are highlighted blue. If the allow rerun switch is set to do rerun, new midsurfaces will be generated using all of the lines that are flagged for collapse.
If allow rerun is disabled, the lines that you manually collapsed will not be used when a new midsurface is extracted.
allow rerun switch Select the behavior of collapsed lines during midsurface extraction.
no rerun
Do not generate new midsurfaces using the lines that you manually collapsed.
prepare for rerun
Highlight the lines that connect associated points on the midsurface blue after extraction.
do rerun
Extract midsurfaces using all of the collapsed lines that were automatically found and the lines that you manually collapsed.
trim surfaces with cut lines selector Select surfaces to trim.
Review Invoke surface review mode.
In surface review mode, click on various surfaces to review its assigned targets and corresponding mid-surface (if there is such information present in the model).
To exit surface review mode, right-click or exit the panel.
drag a cut line Create a line to cut the selected surfaces.
toggle transparency Turn the transparency of transparent components on and off. When the transparency is temporarily turned off, it is often easier to select surfaces.
lines to collapse selector Select lines to collapse.
collapse Collapse selected lines.
delete Delete selected lines.
