Sensors Panel
Use the Sensors panel to create and edit modify sensors.
You can create sensors specific to the solver and modify the type and the fields.
This function requires a template file.
Panel Options
Option Action
name = Specify a name when creating a new sensor, or click to select an existing sensor to edit.
creation method: Click card image = to select the desired card image.
Command Buttons
Button Action
create Create the new sensor using the specified name and card image.
create/edit Create the new sensor using the specified name and card image, then open the card image in edit mode.
edit Change an existing sensor to use the specified card image.
load Load the specified card image.
load/edit Load the specified card image and open it in edit mode.
return Exit the panel.
