Grid Labels Panel
Use the Grid Labels panel to edit the grid labels on the x and y axes of a plot. It allows you to change the font and color of the grid tic marks.
In this panal you can select the format of the grid labels: automatically calculated, exponential, or a user-specified, fixed decimal point. You can also specify the level of precision to be used in the grid labels.
Panel Options
Option Action
plot = Select a plot.
plots (collector) Select the desired plots from the modeling window.
This is an alternative to using the plot= input.
tic color Pick a color to draw the labels.
(font option switch) Choose the font to display labels in.
x: auto / fixed / exponential Select the scale factor for the X axis.
y: auto / fixed / exponential Select the scale factor for the X axis.
precision = Specify the number of decimal places to use in the grid label.
Command Buttons
Button Action
update Update the selected plot(s) to use the current settings.
return Exit the panel.
