Ruled Panel
Use the Ruled panel to create surfaces and/or meshes of plate elements from nodes, lines, and/or line segments, in any combination.
Nodes in the mesh being created are placed on a surface created on a linear basis between the two sets of selected entities.
Panel Options
Option Action
node list / line list Select a node list or a line list. The surfaces or meshes will be generated in the intervening space between the selected nodes and/or lines.
meshing options
mesh, keep surf
Create a surface from the selected entities and then generate a mesh on the created surface. The created surface is retained along with the mesh.
mesh, dele surf
Create a surface from the selected entities and then generate a mesh on the created surface. The created surface is then deleted and only the corresponding mesh is retained.
mesh w/o surf
Create a mesh between the selected entities using linear interpolation without creating a surface.
surface only
Create a surface from selected entities, but does not create a mesh. You can use the resulting surface to perform any desired geometry cleanup functions or automeshing.
auto reverse / no reverse
When elements are generated, the edges used to create this mesh can be ordered in different directions, causing HyperLife Weld Certification to create a mesh that crosses itself, resembling a bow tie. The order of the edges is determined by the order in which the nodes were selected or the direction of the selected line(s).
auto reverse
Prevent "bow ties" from occurring, and to insure that elements are generated with a similar order on each side of the mesh.
no reverse
Disable this feature.
Command Buttons
Button Action
create Create the ruled surface and/or mesh.
reject Undo the most recent ruled creation.
return Exit the panel.
