Solid Map Panel
Use the Solid Map panel to create a mesh of solid elements in a solid geometric volume.
Only relatively simple solids can be meshed; complex objects must first be partitioned into simpler sections so that the sections can be meshed individually.
Furthermore, even if all solids are mappable, they may not all be meshable at once; you may still need to mesh each mappable solid individually, or only a few at a time. Any given volume can have one of four states, which are color-coded when using the mappable view option on the Visualization toolbar. Although the colors can be customized, the default settings are:
Blue
A solid that has not been edited at all, and therefore is not evaluated for mappability.
Orange
A solid that has been edited, but remains completely unmappable (further partitioning may enable mapping).
Yellow
A solid that is mappable in one direction.
Green
A solid that is mappable in three directions (this is very rare).
Figure 1. . The first cube is mappable in 3 directions, but if 1 corner is split off it becomes mappable in only 1 direction. The corner is not mappable without further partitioning.
HyperLife Weld Certification displays the progress of the solid map meshing process in the status bar. Upon completion, HyperLife Weld Certification displays a report of the mesh quality. The element quality value reported is the worst scaled Jacobian in the mesh. The scaled Jacobian's value may range from 0.0 to 1.0 (best). An elem's scaled Jacobian is a ratio of the elem Jacobian over the Jacobian of an ideal elem of the same configuration. To use other mesh quality measures, go to the Check Elements panel.
Note: All of these subpanels depend on an existing 2D mesh, which is then extrapolated into a 3D mesh based on the parameters you input. The One Volume and Multi Solids subpanels, however, can automatically create 3D mesh directly on solids as long as the solids you select are already mappable.
You can omit the source, the destination, or the along geometry by setting either one of the entity selectors to (none). Only one of these selections can be set to (none); the other two selections are then required to define the volume to fill.
The 2D meshes extruded do not have to be continuous.
The "along" faces do not all have to be defined.
You can create elements with a user-specified bias by selecting linear, exponential, or bellcurve after bias style. Specify the bias intensity value after intensity = and click mesh.
General Subpanel
Use the General subpanel to access all of the possible entry controls for maximum flexibility.
Figure 3.
Figure 4.
Option Action
source geom
Choose a method for selecting source geometry that defines the source face of the 3D volume.
surfs
Select surfaces that define the source face of the volume/solid.
lines
Select lines that define the periphery of the source face.
nodes
Select multiple lists of nodes, each representing the periphery of the source face.
none
No source geometry is defined. The geometry inferred from the elems to drag is considered as source geometry.
elems to drag Select the elements/mesh that correspond to the source face extruded to create the solid mesh. If the source face type chosen is a surface, the elements to drag selection is optional as the elements associated to the surface are automatically selected.
dest geom
Choose a method for selecting the geometry that defines the destination face of the 3D volume.
surfs
Select surfaces that define the destination face of the volume/solid.
lines
nodes
elems to match / smooth dest
elems to match
Select the elements on the destination surface that you wish the 3D mesh to match up with.
smooth dest
Smooth the mesh that is mapped on the destination face when your destination geometry varies greatly from the source geometry.
along parameters Define/set the parameters required for the mesh along the solid map. Set the element size or density (toggle) to be defined in the along direction. This determines the number of elements along the depth of the mapping. If the size or density is set to "0", the element size/density is calculated based on the average element size of the source elements (elems to drag).
along bias style Choose the type of biasing to use while creating nodes in the along direction. The biasing style works in conjunction with biasing intensity. If intensity is set to "0" the biasing is not applied.
intensity Specify the biasing intensity value.
3d elem faces by nodes Select 3d elements faces by nodes as input.
apply orthogonality to along Keep the solid elements generated more perpendicular to the surface faces in the along direction.
Line Drag Subpanel
Use the Line Drag subpanel to select a 2D mesh, and then select a line from the model geometry to use as the mapping direction.
Option Action
elems to match
smooth dest
along geom
Choose a method for selecting the geometry that defines the face of the 3D volume along which you wish to map the mesh.
surfs
Select surfaces to define the mapping face of the volume/solid.
lines
nodes
Select a node list that defines a line along which to map.
mixed
Select any combination of surfaces, lines, 2D elements/shell faces, and/or nodelist/nodepath. When elements are used, the mapped solid mesh maintains the nodal positions with selected elements. They can be equivalenced to have common nodes. While selecting nodelist/nodepath, each selection should represent an edge that connects the source and destination.
Linear Solid Subpanel
Use the Linear Solid subpanel to select two existing 2D meshes and extrapolate a 3D mesh that connects them.
Option Action
elems to match Select the elements on the destination surface that you wish the 3D mesh to match up with.
along geom Choose a method for selecting the geometry that defines the face of the 3D volume along which you wish to map the mesh.
nodes
none
Do not use geometry.
Ends Only Subpanel
Use the Ends Only subpanel to select two opposing surfaces and one 2D mesh, then extrapolate the mesh between the surfaces.
Option Action
source geom
surfs
lines
nodes
none
dest geom
surfs
lines
nodes
elems to match
smooth dest
One Volume Subpanel
Use the One Volume subpanel to select a single, mappable solid volume and create a new 3D mesh for it.
Option Action
volume to mesh Select the solid to mesh.
source hint Select the "beginning" surface that defines the direction of mesh mapping.
dest hint Select the "ending" surface that defines the direction of mesh mapping.
source shells
Select the type of source shells that define the 2D mesh on the initial surface of the solid, and will dictate the output element type when meshing the solids.
mixed
Create hexa and penta elements.
quad
Create only hexa elements.
trias or R-trias
Create only penta elements (right-angle pentas in the case of R-trias).
along geom
surfs
lines
nodes
mixed
smooth dest Smooth the elements on the resulting face of the solid to improve the resulting mesh quality.
elems to solid/surf comp / elems to current comp
Select which component to put the newly-created elements.
Add the elements to the same component that contains the solid and its surfaces.
Add the new elements to the current component.
Multi Solids Subpanel
Use the Multi Solids subpanel to select multiple mappable solids and create 3D meshes for them.
HyperLife Weld Certification can create volume meshes on multiple shapes at the same time, allowing you to mesh solid parts faster.
Note: Complex parts must still be partitioned into multiple simpler solids.
This does not always work for large numbers of solids, even if they are all mappable. In some cases you may need to mesh them a few at a time or even (in extreme cases) individually.
Figure 5.
Clicking mesh in this panel will create the solid mesh if automatic mode had been selected. If the interactive mode was selected, it will create any temporary 2D shell meshes required and assign the node seeding density to all of the along edges. Then it will open the Density subpanel.
Option Action
solid Select the desired solids.
Note: Only solids that are mappable can be meshed.
check geom Checks selected solids for any topological issues. Tiny edges will be colored pink and twisted edges will be colored red.
interactive / automatic
automatic
Create the 3D solid mesh immediately.
interactive
Use the subpanels to enable further control over the mesh density and element mesh patterns.
elem size Specify the size to when initially distributing the nodes to the edges.
source shells
mixed
quad
trias or R-trias
stop meshing on bad jacobian Halt the meshing routines upon the creation of a bad jacobian solid element.
previous settings When creating the temporary surface mesh, honor any prior edge node density settings.
keep 2d mesh Keep any surface mesh associated to selected solids/surfaces.
Thin Solids Subpanel
Use the Thin Solids subpanel to create thin solid meshes. The mesh is created by first generating a 2D mesh on a selected set of faces, and then extruding this mesh to generate solid hexa or wedge elements.
Figure 6. Thin Solids. The first image displays geometry that represents thin, bent sheet metal. The second image displays the mesh, which consists of three layers and mixed element type.
In order to create a thin solid mesh, the solid geometry must meet a certain criteria.
  • The solid entity should be a bent sheet metal solid.
  • You should be able to identify both the Source (start) faces and the Destination faces.
  • Source and destination faces must be connected by side (along) faces which are almost 90 degrees to them.
  • The number of top and bottom faces do not need to match.
  • Side faces do not need to be four-sided.
Option Action
thin solid mesh Select whether to mesh elements or solids.
along surfs/source surfs (may hint) Select surfaces that define the source face of the thin solid. A single surface selection as hint will work.
destination (may hint) Select surfaces that define the destination face of the thin solid. A single surface selection as hint will work.
save src to SAVELIST On detect, will save source surfaces to mark. This can be retrieved in other surface selection panels.
number of layers: Specify the number of layers of elements to build along the normal direction.
element size = / elem_size/thickness
element size
Specify the desired element size.
Figure 7. Element Size = 2 (3 Layers)
elem_size/thickness
Specify the ratio of size to part thickness. Since the element size is based on the part thickness, the mesh will be finer in thinner areas.
Figure 8. Elem_size/Thickness = 2 (3 Layers)
element type = Select the type of elements used in the initial shell mesh from which solid elements are created.
  • R-trias are right-angle triangular elements.
  • Mixed uses quads primarily, but inserts trias when necessary to improve mesh quality.
  • Quads attempts to use quads only, but may still insert some trias where quads simply will not fit.
Figure 9. Trias
Figure 10. Quads (Equal Densities)
Figure 11. Right-Trias
Figure 12. Mixed (Density 10 at Top, 5 at Bottom)
linear or no biasing / exponential biasing /bellcurve biasing Select the biasing affects element growth in successive layers, moving away from the source faces.
No Biasing
All layers are equal in thickness.
Figure 13. Example: No Biasing
Exponential Biasing
Successive layers are exponentially thicker.
Figure 14. Example: Exponential Biasing
Bellcurve Biasing
Layers are progressively thicker near the center, but thinner near the source and destination faces.
Figure 15. Example: Bellcurve Biasing
bias intensity = Specify the biasing intensity value.This numeric value affects how strongly the biasing effect is. When left at zero, no biasing is applied.
elements to current comp / original comp Choose whether to organize the newly created components in the current component, or in the components of the shell elements.
post cleanup elems Choose whether to optimize the generated hex mesh. If checked, optimization is performed to improve Jacobian and warpage quality. Avoids negative Jaobian elements created using thin solid.
Command Buttons
Option Action
mesh Create a solid mesh with all the provided input. The solid mesh created is placed in a collector named solidmap. If that collector does not exist, a new component is created with that name.
reject Reject the last mapped solid mesh created.
equiv/faces Equivalence all of the elements in the solidmap component and create the faces (^faces component) for that component. This function is optional and does not directly impact the solidmap functionality. It allows you to perform faster and easier solid modeling. The solidmap component is equivalenced with an initial tolerance of 1% of element size. When this function is performed, a message is displayed informing you of the number of nodes equivalenced along with the tolerance value used. Any subsequent use of this function without performing additional solid mapping increases the tolerance (to a maximum of 10% element size) before equivalencing again.
return Exit the panel.
