ALE Setup Panel
Use the ALE Setup panel to create and modify input data pertaining to the Arbitrary-Lagrangian-Eulerian.
Important: Only available in the LS-DYNA solver interface.
Create Subpanel
Use the Create subpanel to create ALE groups.
Option Action
name Specify a name for the ALE card.
type Specify a type for the ALE card.
Type (HyperLife Weld Certification Card Image)
LS-DYNA Keyword
ConstdLagSolid
*CONSTRAINED_LAGRANGIAN_IN_SOLID
InitialGasMix
*INITIAL_GAS_MIXTURE
InitialVoid
*INITIAL_VOID_PSID
DatabaseFsi
*DATABASE_FSI
DatabaseFsiSensor
*DATABASE_FSI_SENSOR
BoundAmbEos
*BOUNDARY_AMBIENT_EOS
InitVolFractGeo
*INITIAL_VOLUME_FRACTION_GEOMETRY
InitialALEMapping
*INITIAL_ALE_MAPPING
Additional cards related to ALE modeling:
  • *SECTION_POINT_SOURCE (collector/property panel)
  • *INITIAL_VOLUME_FRACTION (*Element_Solid card image)
color Select a color for the ALE group.
Add/Update Subpanel
Use the Add/Update subpanel to link entities such as components or a set to the ALE cards created in the Create subpanel.
Option Action
options Use the entity selector to select entities to link to the ALE card.
Command Buttons
Button Action
create Create the ALE card.
update Update the selected card with the new information.
create/edit Create the ALE card and immediately open the Card Editor with the ALE card loaded.
review Highlight the selected mass element.
edit Open the Card Editor with the current ALE card loaded.
update color Update the ALE card color with the newly selected color.
return Exit the panel.
