/MAT/LAW63 (HANSEL)
Block Format Keyword This law describes the trip steel plastic material. This material law can be used only with shell elements.
/MAT/LAW63/mat_ID/unit_ID or /MAT/HANSEL/mat_ID/unit_ID
mat_title
ρ i
E ν Cp
A B Q C D
P AHS BHS m n
K1 K2 ΔH Vm0 ε ˙ 0
T0 Hl η
mat_ID Material identifier.
(Integer, maximum 10 digits)
unit_ID Unit Identifier.
mat_title Material title.
ρ i Initial density.
(Real)
[ kg m 3 ]
E Initial Young's modulus.
(Real)
[ Pa ]
v Poisson's ratio.
(Real)
Cp Specific heat capacity.
Default = 1030 (Real)
[ J kg⋅K ] MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeaaciGaaiaabeqaamaabaabaaGcbaWaamWaaeaada WcaaqaaiaabQeaaeaacaqGRbGaae4zaiabgwSixlaabUeaaaaacaGL BbGaayzxaaaaaa@3DB3@
A Material parameter 1.
(Real)
B Material parameter 2. 5
Default = -1.0 (Real)
Q Material parameter 3.
(Real)
[ K ]
C Material parameter 4.
(Real)
D Material parameter 5.
(Real)
[ 1 K ] MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeaaciGaaiaabeqaamaabaabaaGcbaWaamWaaeaada WcaaqaaiaaigdaaeaacaWGlbaaaaGaay5waiaaw2faaaaa@3981@
P Material parameter 6.
(Real)
AHS Material parameter 7.
(Real)
BHS Material parameter 8.
(Real)
[ Pa ]
m Material parameter 9.
(Real)
[ Pa ]
n Material parameter 10.
(Real)
K1 Material parameter 11.
(Real)
K2 Material parameter 12.
(Real
Δ H Material parameter 13.
(Real
[ Pa ]
Vm0 Initial martensite fraction.
Default = 10-20 (Real)
ε ˙ 0 Initial plastic strain.
(Real)
T0 Initial temperature.
(Real)
[ K ]
Hl Latent heat of martensite.
(Real)
[ J ]
η Taylor-Quinney coefficient.
Default = 1.0 (Real)
Example (Steel)
#RADIOSS STARTER
/UNIT/1
unit for mat
                  Mg                  mm                   s
#-  2. MATERIALS:
/MAT/LAW63/1/1
Steel
#              RHO_I
              7.8E-9
#                  E                  Nu                  Cp
              210000                  .3           460000000
#                  A                   B                   Q                   C                   D
                 .32                .226              1379.4              -2.173               .0084
#                  P                 AHS                 BHS                   m                   n
                6.25               318.2                2170                2.94                1.39
#                 K1                  K2                  DH                VM_0                EPS0
                   1                   0               414.7                1E-4                .002
#                 T0                  Hl                 eta
                 273                 150                 0.9
#ENDDATA
/END
  1. Martensite fraction rate:(1)
    ∂ V m ∂ ε p = B A exp ( Q T ) ( 1 − V m V m ) ( 1 + B ) B V m P 1 2 [ 1 − tanh ( C + D ⋅ T ) ]
  2. Martensite fraction:(2)
    V m = ∫ 0 ε p ∂ V m ∂ ε p ∂ ε p
  3. Mechanical behavior:(3)
    σ y = ( B HS − ( B HS − A HS ) exp ( − m ( ε p + ε 0 ) n ) ) ( K 1 + K 2 T ) + Δ H γ → α , V m
  4. The temperature is computed assuming the adiabatic condition (by default the condition is isothermal with Cp = 1030):(4)
    T= T 0 + η  E int  +   V m   H l ρ C p ( Volume ) MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVCI8FfYJH8YrFfeuY=Hhbbf9v8qqaqFr0xc9pk0xbb a9q8WqFfeaY=biLkVcLq=JHqpepeea0=as0Fb9pgeaYRXxe9vr0=vr 0=vqpWqaaeaabiGaciaacaqabeaadaqaaqaaaOqaaabaaaaaaaaape Gaamivaiabg2da9iaadsfapaWaaSbaaSqaa8qacaaIWaaapaqabaGc peGaey4kaSYaaSaaa8aabaWdbiabeE7aOjaacckacaWGfbWdamaaBa aaleaapeGaamyAaiaad6gacaWG0baapaqabaGcpeGaaiiOaiabgUca RiaacckacaGGGcGaamOva8aadaWgaaWcbaWdbiaad2gaa8aabeaak8 qacaGGGcGaamisa8aadaWgaaWcbaWdbiaadYgaa8aabeaaaOqaa8qa cqaHbpGCcaWGdbWdamaaBaaaleaapeGaamiCaaWdaeqaaOWdbmaabm aapaqaa8qacaWGwbGaam4BaiaadYgacaWG1bGaamyBaiaadwgaaiaa wIcacaGLPaaaaaaaaa@56FF@
    Where, Eint is the internal energy of the element.
  5. B must satisfy this condition:(5)
    1 + B B < p
  6. The Taylor-Quinney coefficient must satisfy this condition:(6)
    0≤η≤1 MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVCI8FfYJH8YrFfeuY=Hhbbf9v8qqaqFr0xc9pk0xbb a9q8WqFfeaY=biLkVcLq=JHqpepeea0=as0Fb9pgeaYRXxe9vr0=vr 0=vqpWqaaeaabiGaciaacaqabeaadaqaaqaaaOqaaabaaaaaaaaape GaaGimaiabgsMiJkabeE7aOjabgsMiJkaaigdaaaa@3C97@
