Radioss
Radioss
2021.2
  1. Home
  2. Reference Guide
  3. Optimization Keywords
  • What's New
  • Overview
  • Tutorials
  • User Guide
  • Reference Guide
  • Example Guide
  • Verification Problems
  • Frequently Asked Questions
  • Theory Manual
  • User Subroutines
  • Starter Input
  • Engine Input
Index
Radioss
2021.2
Radioss
  • What's New
    View new features for Radioss 2021.2.
  • Overview
  • Tutorials
  • User Guide
  • Reference Guide
    • File Extensions and Formats
      Radioss format 2021 uses the 12x extension format.
    • Single File Input
    • New Keywords in 2021
    • Starter Input
    • Engine Input
    • LS-DYNA Input (Beta)
      This manual contains an alphabetical list of LS-DYNA input files available in Radioss.
    • Optimization Keywords
      • Bulk Data
        Optimization Keyword This group of keywords are used to insert Bulk format data into <name>.radopt file.
      • Design Constraints
        Optimization Keyword In this group, keywords are used to define the design constraints.
      • Design Response
        Optimization Keyword In this group, keywords are used to define the design response in optimization.
      • Design Variables
        Optimization Keyword In this group, keywords are used to define the design variable in optimization.
      • /DEQATN
        Optimization Keyword Specifies one or more equations for use in optimization.
      • /DESOBJ
        Optimization Keyword This keyword can be used to select a response as the objective function of an optimization run by selecting a response as the objective function. The selected response can either be minimized or maximized based on the inputs specified on this keyword.
      • /DTABLE
        Optimization Keyword List of constants to be used in functions defined by /DEQATN.
      • /DVGRID
        Optimization Keyword Defines the relationship between design variable and grid point location.
      • /ESLPART
        Optimization Keyword Defines parts in the model which will be included in ESLM optimization.
    • Multi-Domain
      This manual contains the description of the Keywords for the Radioss Multi-Domain.
    • Other Files
    • Definitions
  • Example Guide
  • Theory Manual
  • User Subroutines
  • Starter Input
  • Engine Input
View All Altair Simulation Help
Radioss
Radioss
2021.2
  1. Home
  2. Reference Guide
  • What's New
  • Overview
  • Tutorials
  • User Guide
  • Reference Guide
  • Example Guide
  • Theory Manual
  • User Subroutines
  • Starter Input
  • Engine Input
Index
Below is an alphabetical list of optimization entries.
/BULK
/BULKFMT
/BULKMAT
/BULKPROP
/DCOMP
/DCONSTR
/DEQATN
/DESOBJ
/DESVAR
/DRESP1
/DRESP2
/DSHAPE
/DSIZE
/DTABLE
/DTPG
/DTPL
/DVGRID
/DVPREL1
/DVPREL2
/ESLPART
  • Bulk Data
  • Design Response
  • Design Variables
  • /DEQATN
  • /DESOBJ
  • /DTABLE
  • /DVGRID
  • /ESLPART
