2D and 3D Analysis Options
  2D 3D
Quad ✓
Solid   ✓
Shell 4 Node   ✓
Shell 3 Node   ✓
Truss   ✓
Beam   ✓
Spring   ✓
Concentrated load ✓ ✓
Pressure load ✓ ✓
Initial velocity ✓ ✓
Fixed velocity ✓ ✓
Gravity ✓ ✓
Interface Type 1, 2, 3, and 5 all
Rigid wall Type 1 all
Rigid body   ✓
Added mass   ✓
Section   ✓
Cylindrical joint   ✓
Monitored Volumes   ✓
Property Type 14
/DFS/DTPLAN, /DFS/DETPOIN, /DFS/DETLINE, /DFS/LASER, /DFS/WAV_SHA ✓
/UPWM ✓
/UPWIND ✓
/ALE/BCS ✓
/ALE/GRID/DISP, /ALE/GRID/DONEA,
/ALE/GRID/SPRING,
/ALE/GRID/STANDARD, /ALE/GRID/ZERO
/ALE/CLOSE ✓
/ALE/MAT ✓
/ALE/LINK/VEL ✓
/AMS
/EULER/MAT ✓
✓ : yes
blank : no
