Strain Rate
The relationship between the physical coordinate and computational intrinsic coordinates system for a brick element is given by the matrix equation:(1)
[ Φ I ξ Φ I η Φ I ζ ] = [ x ξ y ξ z ξ x η y η z η x ζ y ζ z ζ ] . [ Φ I x Φ I y Φ I z ] = F ξ . [ Φ I x Φ I y Φ I z ]
Hence:(2)
[ Φ I x i ] = F ξ 1 . [ Φ I ξ ]
Where, F ξ is Jacobian matrix.
The element strain rate is defined as:(3)
ε ˙ i j = 1 2 ( v i x j + v j x i )
Relating the element velocity field to its shape function gives:(4)
v i x j = I = 1 8 Φ I x j v i I
Hence, the strain rate can be described directly in terms of the shape function:(5)
ε ˙ i j = 1 2 ( v i x j + v j x i ) = I = 1 8 Φ I x j v i I
As was seen in Velocity Strain or Deformation Rate, volumetric strain rate is calculated separately by volume variation.
For one integration point:(6)
Φ 1 x j = Φ 7 x j ; Φ 2 x j = Φ 8 x j ; Φ 3 x j = Φ 5 x j ; Φ 4 x j = Φ 6 x j
F.E Method is used only for deviatoric strain rate calculation in A.L.E and Euler formulation.
Volumetric strain rate is computed separately by transport of density and volume variation.
