Solid Tetrahedron Elements
4-Node Solid Tetrahedron
The Radioss solid tetrahedron element is a 4 node element with one integration point and a linear shape function.
This element has no hourglass. But the drawbacks are the low convergence and the shear locking.
10-Node Solid Tetrahedron
The Radioss solid tetrahedron element is a 10 nodes element with 4 integration points and a quadratic shape function as shown in Figure 1.
Figure 1. (a) Isoparametric 10 Node Tetrahedron; (b) Nodal Mass Distribution
Introducing volume coordinates in an isoparametric frame:
L 1 = r
L 2 = s
L 3 = t
L 4 = 1 L 1 L 2 L 3
The shape functions are expressed by:(1) Φ 1 = ( 2 L 1 1 ) L 1 (2) Φ 2 = ( 2 L 2 1 ) L 2 (3) Φ 3 = ( 2 L 3 1 ) L 3 (4) Φ 4 = ( 2 L 4 1 ) L 4 (5) Φ 5 = 4 L 1 L 2 (6) Φ 6 = 4 L 2 L 3 (7) Φ 7 = 4 L 3 L 1 (8) Φ 8 = 4 L 1 L 4 (9) Φ 9 = 4 L 2 L 4 (10) Φ 10 = 4 L 3 L 4
Location of the 4 integration points is expressed by 1.
  L 1 MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamitamaaBa aaleaacaaIXaaabeaaaaa@37AE@ L 2 MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamitamaaBa aaleaacaaIXaaabeaaaaa@37AE@ L 3 MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamitamaaBa aaleaacaaIXaaabeaaaaa@37AE@ L 4 MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamitamaaBa aaleaacaaIXaaabeaaaaa@37AE@
a α β β β
b β α β β
c β β α β
d β β β α
With,
α = 0 58541020 and β = 0 13819660 .
a, b, c, and d are the 4 integration points.
Advantages and Limitations
This element has various advantages:
  • No hourglass
  • Compatible with powerful mesh generators
  • Fast convergence
  • No shear locking.
But there are some drawbacks too:
  • Low time step
  • Not compatible with ALE formulation
Time Step
The time step for a regular tetrahedron is computed as:(11) d t = L c c
Where, L c is the characteristic length of element depending on tetra type. The different types are:
Figure 2. Regular 4 Nodes Tetra
(12) L c = a 2 3 ; L c = 0.816 a
Figure 3. Regular 10 Nodes Tetra
(13) L c = a 5 / 2 6 ; L c = 0.264 a
For another regular tetra obtained by the assemblage of four hexa as shown in Figure 4, the characteristic length is:
Figure 4. Other Regular Tetra
(14) L c = a 2 / 3 4 ; L c = 0.204 a
CPU Cost and Time/Element/Cycle
The CPU cost is shown in Figure 5:
Figure 5. CPU Cost in TEC
Example: Comparison
Below is a comparison of the 3 types of elements (8-nodes brick, 10-nodes tetra and 20-nodes brick). The results are shown in Figure 6 for a plastic strain contour.
Figure 6. Comparison (plastic strain max = 60%)
1 Hammet P.C., Marlowe O.P. and Stroud A.H., “Numerical integration over simplexes and cones”, Math. Tables Aids Comp, 10, 130-7, 1956.
