Starter and Engine Setup
The Runname_nnnn.sta is written by entering the following keyword in the Radioss Engine files.
This must be set in /STATE/DT in the Engine file.
   /STATE/DT
   Tstart    Tfreq
   Part_ID1 ... Part_IDN
STATE files are written with a time frequency Tfreq, the first file being written at time Tstart.
As of Version 11.0, /STATE/STR_FILE can also be used in Engine file to write /INISHE, /INISH3 and /INIBRI in a separate file, which can be compressed (using GZIP).
This file can be read in Starter with the same keyword /STATE/STR_FILE (Runname_run#.sta File).
Corresponding Starter and Engine Keywords
Starter Keywords Engine Keywords Comment
/INIBEAM/AUX /STATE/BEAM/AUX Writes Auxiliary variable of beam into each state file.
/INIBEAM/FULL /STATE/BEAM/FULL Writes force, moment, energy and so on for beam into each state file.
/INIBRI/AUX /STATE/BRICK/AUX/FULL Writes Auxiliary variable of solid into each state file.
/INIBRI/STRA_F /STATE/BRICK/STRAIN/FULL Writes Strain full of solid into each state file.
/INIBRI/STRA_FGLO /STATE/BRICK/STRAIN/GLOBFULL Writes Strain state for solid in global system into each state file.
/INIBRI/STRS_F /STATE/BRICK/STRES/FULL Writes Stress full of solid into each state file.
/INIBRI/STRS_FGLO /STATE/BRICK/STRES/GLOBFULL Writes Stress state for solid in global system into each state file.
/INIBRI/FAIL /STATE/BRICK/FAIL Writes failure criteria of solid to each state file.
/INIBRI/ORTHO /STATE/BRICK/ORTHO Writes orthotropy direction of orthotropic solid to each state file.
/INISHE/AUX or /INISH3/AUX /STATE/SHELL/AUX/FULL Writes Auxiliary variable of shell into each state file.
/INISHE/EPSP_F or /INISH3/EPSP_F /STATE/SHELL/EPSP/FULL Writes plastic strain in an integration point of shell element into each state file.
/INISHE/FAIL /STATE/SHELL/FAIL Writes failure criteria of shell element to each state file.
/INISHE/ORTH_LOC or /INISH3/ORTH_LOC /STATE/SHELL/ORTHL Writes the orthotropy direction of each shell in each state file.
/INISHE/STRA_F or /INISH3/STRA_F /STATE/SHELL/STRAIN/FULL Writes Strain full of shell into each state file.
/INISHE/STRS_F/GLOB or /INISH3/STRS_F/GLOB /STATE/SHELL/STRESS/FULL Writes Stress full of shell into each state file.
/INISPRI/FULL /STATE/SPRING/FULL Writes stress state of spring into each state file.
/INITRUSS/FULL /STATE/TRUSS/FULL Writes force, energy and so on for truss into each state file.
/INITEMP /STATE/NODE/TEMP Writes temperature for node into each state file.
/STATE/LSENSOR Write state file due to sensor activation.
Runname_0001.rad Example
/TITLE
specimen
/VERS/140
/RUN/TEST_LOI70_INISTA/1
0.0001
/DT/NODA/CST
0 0.0002
/TFILE/4
#            dT_HIS
0.001000
/PRINT/-1
/ANIM/DT
#   TSTART     TFREQ
0.000000 0.200000
/ANIM/MASS
/ANIM/GZIP
/MON/ON
/STATE/DT
#   TSTART     TFREQ
0.000000 0.100000
1
Runname_0001.sta File Example
#RADIOSS STATE FILE TEST_LOI70_INISTA_0001.sta
/BRICK/         1
#  BRICKID      NOD1      NOD2      NOD3      NOD4      NOD5      NOD6      NOD7      NOD8
      2264      2362      2363      2403      2402     15496     15499     15500     15497
      2265      2363      2364      2404      2403     15499     15501     15502     15500
      2266      2364      2365      2405      2404     15501     15503     15504     15502
     16049     17932     17933     17973     17972      7918      7919      7959      7958
/NODE
#    NODID               XCOOR               YCOOR               ZCOOR
      2362-9.4860320632213E+01-9.7566652635510E+01-2.1349724131947E+02
      2363-8.9732511272041E+01-9.7566504906095E+01-2.1354273831056E+02
      2403-8.9732587846314E+01-9.2432640570356E+01-2.1354276090585E+02
#---1----|----2----|----3----|----4----|----5----|----6----|----7----|----8----|----9----|----10---|
/INIBRI/STRA_F
#------------------------ REPEAT -------------------------
#  BRICKID       NPT    ISOLNOD    ISOLID
# IF(NPT /= 0) REPEAT K=1,NPT
#    E1,  E2,  E3
#   E12, E23, E31
      2264         1         8         1
-5.0438655364508E-05 8.6229170230857E-04 2.8990365078826E-05
 2.3469460795598E-06 6.5900445290114E-06 1.5812215799661E-04
      2265         1         8         1
-1.8719100585017E-04 9.3265313414179E-04 6.8570078668737E-05
 1.2843456314422E-05-1.9218559255100E-05-5.1933993650876E-05
      2266         1         8         1
-3.0710035014301E-04 1.0160141185918E-03 1.7571927484993E-04
-2.0907794611084E-05-8.9656877740873E-06-2.1109233934431E-04
/INIBRI/AUX
#------------------------ REPEAT --------------------------
#  BRICKID       NPT
# IF(NPT /= 0) REPEAT K=1,NPT : REPEAT I=1,NPG :
#    S1,  S2,  S3
#   S12, S23, S31
#---------------------- END REPEAT ------------------------
      2264         1         8         1         0         0        10
 0.0000000000000E+00 1.7602676312553E-05 2.0357600000000E-02
 8.7146844804545E-04 0.0000000000000E+00 1.7602676312553E-05
 0.0000000000000E+00 6.7762635780344E-21 9.5516513254258E-04
 1.2688798747243E-02
      2265         1         8         1         0         0        10
 0.0000000000000E+00 1.9007938166799E-05 2.8620778174113E-02
 9.5456792347511E-04 0.0000000000000E+00 1.9007938166799E-05
 0.0000000000000E+00 4.1064089095073E-02 3.3000834605586E-02
 4.1013062401391E-02
      2266         1         8         1         0         0        10
 3.9825245072209E-02 2.1859375758609E-05 2.0357600000000E-02
 1.0862832620320E-03 0.0000000000000E+00 2.1859375758609E-05
 0.0000000000000E+00 0.0000000000000E+00 3.2513011703713E-02
 1.3552527156069E-20
#ENDDATA
  1. The first lines of an element are always written, even if there is no element of that type. In such a case, a line is left blank below the option.
  2. First line is always #RADIOSS Runname_nnnn.sta according to the /IOFLAG keyword.
  3. The Runname_nnnn.sta file always finishes with #ENDDATA.
