/STATE/SHELL/AUX/FULL
Engine Keyword Describes the internal variable state for shell.
  1. A block /INISHE/AUX or /INISH3/AUX is written into each state file, for each part declared into /STATE/DT, including the additional internal variables which might be needed for the state of the shells to be completely restored.
  2. A block /INISHE/AUX or /INISH3/AUX is written into each state file, for each part declared into /STATE/DT, including the additional internal variables, which might be needed for the state of the shells to be completely restored.
  3. No block is written for a part if its shells or 3-node shells do not use any additional internal variable.
