/STATE/SHELL/EPSP/FULL
Engine Keyword Describes the Epsilon plastic state for shell.
  1. A block /INISHE/EPSP_F or /INISH3/EPSP_F is written into each state file, for each part declared into /STATE/DT, including the full plastic strain description of the shells belonging to it.
  2. A block /INISHE/EPSP_F or /INISH3/EPSP_F is written into each state file, for each part declared into /STATE/DT, including the full plastic strain description of the 3-node shells belonging to it.
