/STATE/SHELL/FAIL
Engine Keyword Describes the failure criteria state for shell.
/STATE/SHELL/FAIL
- A block /INISHE/FAIL is written into each state file (*.sta), for each part declared into /STATE/DT.
- The failure identifier fail_ID must be defined in the /FAIL model, so that the failure state is associated with the correct failure model. If fail_ID is not defined in /FAIL, then no failure information is printed in /INISHE/FAIL of the state file.
