Animation Output File (A-File)
The RunnameAnnn file is a binary file, containing both model and result data. It can be used to post-process results in HyperView.
File Creation
The RunnameAnnn files are created during a Radioss Engine run. These files are written under the name RunnameAnnn, with nnn being the output file number.
File Contents
The RunnameAnnn files contain node and element definitions, in addition to the following results:
Result
Vector Data
Velocities, displacements, accelerations, contact forces, internal forces, external forces, forces and moments for rigid bodies, rigid walls and sections, rotational velocities, fluid velocities (for incompressible fluid flow by BEM).
Output is controlled by /ANIM/VECT.
Element Data
Spring damage, density, energy, plastic strain, equivalent strain rate, failed layers, hourglass energy, pressure, stress tensor, temperature, thickness, von Mises stress, user law results.
Output is controlled by /ANIM/Eltyp/Restype.
Nodal Mass
Nodal mass results.
Output is controlled by /ANIM/MASS.
Nodal Data
Time step, mass variation, added inertia per node.
Output is controlled by /ANIM/NODA.
