Control File (C-File)
The optional control file is used to get information about a currently running analysis.
While a simulation is running, it can be very useful to find out more information than is printed in the Engine output file. This can be done using a Radioss control file which has the same prefix name as the current Engine input file but ends in *.ctl. If the current running Engine file is named TensileTest_0001.rad, then the control file should be named TensileTest_0001.ctl.
- Retrieve the current state of the simulation including current simulation time, time step, cycle, energy information, and estimated remaining time
- Stop the computation immediately, or at a specified time or cycle number
- Create an animation immediately, or at a specified time or cycle number
![](../../../images/solvers/hwsolvers_run_mgr_send_command.png)
If the Compute Console (ACC) is not being used, the control file can be created using a text editor and saved in the directory where Radioss is writing the Engine output file.
- Action
- Result
- /ANIM
- Create an extra animation file (A###). The output frequency defined in the Engine file will not change when this option is used.
- /CHKPT
- Create a file named CHECK_DATA which contains /RERUN commands to continue a simulation if it is stopped. Usually used in combination with /STOP to stop the simulation. Not available with the implicit solution.
- /CYCLE/cycleNumber
- The control file commands will be executed at the specified cycle number.
- /H3D
- Write animation data to the *.h3d file. The output frequency defined in the Engine file will not change when this option is used.
- /INFO
- Returns information on current cycle, current global energies, current time step. This information is always written for all options.
- /KILL
- Kill the simulation and do not create a restart file.
- /RFILE
- Create a restart file.
- /STOP
- Stop the simulation and create a restart file, so it can be restarted.
- /TIME/timeValue
- The other control file commands will be executed at the specified simulation time.
When Radioss detects the control file, the current status of the simulation is written in the same control file using the options were entered.
/TIME/.1
/ANIM
/CHKPT
/STOP
RUN CONTROL FILE
WRITE NEXT ANIMATION FILES AT TIME 0.1000000
WRITE NEXT RESTART FILE AT TIME 0.1000000
RUN STOP AT TIME 0.1000000
CURRENT STATE:
CYCLE = 13040
TIME = 0.8153611E-02
TIME STEP = 0.6252749E-06SOLID 70
ENERGY ERROR = 0.0%
INTERNAL ENERGY = 0.1188329E-02
KINETIC ENERGY = 0.1050914E-07
ROT. KIN. ENERGY = 0.000000
EXTERNAL WORK = 0.1188431E-02
MASS.ERR (M-M0)/M0= 0.000000
CURRENT ELAPSED TIME = 4.88 s
REMAINING TIME ESTIMATE = 594.04 s
