Output Available
The Runname_run#.sty file can be written by a previous Engine run with the following options.
/OUTP/VECT/VEL (for nodal translational).
/OUTP/VECT/DIS
/OUTP/VECT/ACC
/OUTP/VECT/CONT
/OUTP/VECT/FINT
/OUTP/VECT/FEXT
/OUTP/VECT/FOPT
/OUTP/VECT/VROT (for nodal rotational velocities)
/OUTP/VECT/PCONT
/OUTP/NODA/DT
/OUTP/NODA/DMAS
/OUTP/SOLI or /OUTP/BRIC or /OUTP/QUAD can be used for the following keywords:
/OUTP/BRIC/OFF
/OUTP/BRIC/EPSP (solid plastic strain)
/OUTP/BRIC/ENER (solid internal energy)
/OUTP/BRIC/DENS (solid density)
/OUTP/BRIC/TEMP
/OUTP/BRIC/P
/OUTP/BRIC/VONM
/OUTP/BRIC/STRAI/FULL
/OUTP/BRIC/STRES (stress tensor for solids)
/OUTP/BRIC/STRES/FULL (available for 1 and 8 integration points; available for 8, 10, 16 and 20 node brick elements)
/OUTP/BRIC/USER1
/OUTP/BRIC/USER2
/OUTP/BRIC/USER3
/OUTP/BRIC/USER4
/OUTP/BRIC/USER5
/OUTP/BRIC/USERS/FULL
/OUTP/BRIC/HOUR
/OUTP/NODA/DINER
/OUTP/SHEL/OFF
/OUTP/SHEL/EPSP
/OUTP/SHEL/USER1
/OUTP/SHEL/USER2
/OUTP/SHEL/USER3
/OUTP/SHEL/USER4
/OUTP/SHEL/USER5
/OUTP/SHEL/USRii/FULL
/OUTP/SHEL/HOUR
/OUTP/SHEL/ENER
/OUTP/SHEL/THIC
/OUTP/SHEL/VONM
/OUTP/SHEL/STRES/MEMB
/OUTP/SHEL/STRES/BEND
/OUTP/SHEL/STRES/UPPER
/OUTP/SHEL/STRES/LOWER
/OUTP/SHEL/STRES/FULL
/OUTP/SHEL/STRAI/MEMB
/OUTP/SHEL/STRAI/BEND
/OUTP/SHEL/STRAI/UPPER
/OUTP/SHEL/STRAI/LOWER
/OUTP/SHEL/STRAI/FULL (strain tensor)
/OUTP/SHEL/EPSDO/MEMB
/OUTP/SHEL/EPSDO/BEND
/OUTP/SHEL/EPSDO/UPPER
/OUTP/SHEL/EPSDO/LOWER
/OUTP/SHEL/USERS/FULL
/OUTP/TRUS/OFF
/OUTP/TRUS/EPSP
/OUTP/SPRI/OFF
/OUTP/SPRI/FULL
/OUTP/BEAM/OFF
/OUTP/BEAM/EPSP
/OUTP/ELEM/OFF
/OUTP/ELEM/EPSP
/OUTP/ELEM/ENER
/OUTP/ELEM/VONM
/OUTP/ELEM/USER1
/OUTP/ELEM/USER2
/OUTP/ELEM/USER3
/OUTP/ELEM/USER4
/OUTP/ELEM/USER5
/OUTP/ELEM/HOUR
/OUTP/ELEM/SLEN
Initial state file available for SPH
/OUTP/SPH/OFF
/OUTP/SPH/EPSP
/OUTP/SPH/ENER
/OUTP/SPH/DENS
/OUTP/SPH/TEMP
/OUTP/SPH/P
/OUTP/SPH/VONM
/OUTP/SPH/STRES
/OUTP/SPH/STRES/FULL
/OUTP/SPH/SLEN current smoothing length value/OUTP/SPH/USER1
/OUTP/SPH/USER2
/OUTP/SPH/USER3
/OUTP/SPH/USER4
/OUTP/SPH/USER5
