Runname_0000.sty Files
The Runname_0000.sty file is created by RADIOSS Starter using Ioutp = 1 in the /IOFLAG keyword.
/IOFLAG
#     IPRI               IGTYP     IOUTP    IOUTYY   IROOTYY
0                   0         1         0         0
This file contains general information on the model and is compulsory in order to be able to use subsequent output files.
Runname_0000.sty file information is structured in sets, using the following syntax:
/"Keyword" -> type of information
Full name of information
#FORMAT: -> data format (in Fortran) for this set.
Format is always I10 for (Integers) and G20 for (Real).
# -> name of each data
data values
Example of Runname_0000.sty file
#RADIOSS OUTPUT FILE V21 TEST_LOI70_0000.sty
/HEAD
specimen
/CONTROL
Control information
#FORMAT: (3I10)
#   NUMMID    NUMPID    NUMNOD
3         6     22656
#FORMAT: (7I10)
#   NUMSOL   NUMQUAD   NUMSHEL   NUMTRUS   NUMBEAM   NUMSPRI   NUMSH3N    NUMSPH
17610         0         0         0         0         0         0         0
/MID
Material ID information
#FORMAT: (2I10,A40)
# SYSMID  USRMID                                 MIDHEAD
1       1MAT_RIGID_5
2       2PU62IF70
1         1MAT_RIGID_5
2         2PU62IF70
/PID
Property ID information
#FORMAT: (2I10,A40)
# SYSPID  USRPID                                 PIDHEAD
1         1SECTION_SOLID_1
2         2SECTION_SOLID_3
3         3SECTION_SOLID_5
4         4SECTION_SOLID_6
5         5SECTION_SOLID_8
6         6SECTION_SOLID_9
/SOLID
3d Solid Elements
#FORMAT: (4I10/8X,8I10)
# SYSSOL  USRSOL  SYSMID  SYSPID
#SYSNOD1 SYSNOD2 SYSNOD3  SYSNOD4 SYSNOD5 SYSNOD6 SYSNOD7 SYSNOD8
1      7806         1         3
9621      9622     10064     10063      9643      9644     10084     10083
2      7807         1         3
10063     10064     10066     10065     10083     10084     10086     10085
3      7808         1         3
10065     10066     10068     10067     10085     10086     10088     10087
/QUAD
2d Solid Elements
#FORMAT: (8I10)
#SYSQUAD USRQUAD  SYSMID  SYSPID SYSNOD1 SYSNOD2 SYSNOD3 SYSNOD4
/SHELL
3d Shell Elements
#FORMAT: (8I10)
#SYSSHEL USRSHEL  SYSMID  SYSPID  SYSNOD1  SYSNOD2  SYSNOD3  SYSNOD4
/TRUSS
3d Truss Elements
#FORMAT: (6I10)
#SYSTRUS USRTRUS  SYSMID  SYSPID SYSNOD1 SYSNOD2
/BEAM
3d Beam Elements
#FORMAT: (7I10)
#SYSBEAM USRBEAM  SYSMID  SYSPID SYSNOD1 SYSNOD2 SYSNOD3
/SPRING
3d Spring Elements
#FORMAT: (6I10)
#SYSSPRI USRSPRI  SYSMID  SYSPID SYSNOD1 SYSNOD2
/SHELL3N
3d Shell Elements (Triangle)
#FORMAT: (7I10)
#SYSSH3N    USRSH3N     SYSMID   SYSPID    SYSNOD1    SYSNOD2    SYSNOD3
/SPHCEL
SPH particles
#FORMAT: (4I10/10X,I10)
#SYSSPH    USRSPH    SYSMID    SYSPID
#SYSNOD
/ENDDATA
  1. The first column of data represents the system number. The second column is your number. Element definition always refers to system numbers.
    # SYSNOD USRNOD X Y Z MASS
    1
    2
    3
    4
    5
    6
    7
    8
    9
    13
    14
    15
    16
    17
    18
    19
    20
    21
    100.0000000000
    100.0000000000
    100.0000000000
    100.0000000000
    97.98561000000
    95.97123000000
    93.95684050000
    91.94245910000
    89.92807010000
    0.000000000000
    2.000000000000
    4.000000000000
    6.000000000000
    6.000000000000
    6.000000000000
    6.000000000000
    6.000000000000
    6.000000000000
    0.000000000000
    0.000000000000
    0.000000000000
    0.000000000000
    0.000000000000
    0.000000000000
    0.000000000000
    0.000000000000
    0.000000000000
    4.5971794829250E-03
    9.2036861619406E-03
    9.2223408546703E-03
    4.6158341756547E-03
    9.2299679301626E-03
    9.2280286296261E-03
    9.2277378193729E-03
    9.2276929864920E-03
    9.2277011693767E-03
  2. The three first lines of an element are always written, even if there is no element of that type. In such a case, a line is left blank below the option.
  3. First line is always: "# Radioss Output File V21 RunnameY000" or "# Radioss Output File V21 Runname_nnnn.sty" according to the /IOFLAG keyword.
  4. The second line contains "/HEAD", and the third is the title of the model (format is A100).
    /HEAD
    specimen
    /CONTROL
  5. The Y000 or sty file always finishes with the keyword "/ENDDATA".
  6. The dummy material which is added (by Radioss) in the Runname_run#.sty file, corresponds to a part which has no material.
