/IOFLAG
Block Format Keyword Describes the input-output flags.
| /IOFLAG | |||||||||
| Ipri | Ioutp | OutyyFmT | Irootyy | Idrot | |||||
| Ipri | Starter output printout flag
(Integer) |
| Ioutp | Output a STY model file flag
(Integer) |
| OutyyFMT | STY file output format flag
(Integer) |
| Irootyy | STY file name flag
(Integer) |
| Idrot | Force computation of
rotational DOF flag
(Integer) |
- run#: Radioss run number (four digits) from 0000 to 9999.
- OutyyFmT = 2 is only working if all IDs (node, element, ...) are using less than 9 digits.
- Only Binary 64-bit restart file can be used.
