/INIBEAM/AUX
Block Format Keyword This option is used to initialize internal variables of user type material laws for beams (UVAR buffer).
/INIBEAM/AUX
beam_ID nb_integr prop_type nvars
For each integration point (nb_integr > 0):
V1 V2 V3     Vnvars
beam_ID Element identifier.
(Integer)
nb_integr Integration point number through the section. 1
It corresponds to the property definition of this element.
(Integer)
prop_type Beam property set. 2
(Integer)
nvars Number of auxiliary internal variables. 3
(Integer)
V1 1st auxiliary variable value.
(Real)
V2 2nd auxiliary variable value.
(Real)
V3 3rd auxiliary variable value.
(Real)
Vnvars nvarsth auxiliary variable value.
(Real)
  1. The nb_integr must be equal to the number of integration points given in the beam property.
  2. /STATE/BEAM/AUX is available only for property TYPE18 (integrated beam, nb_integr > 0).
  3. The nvars is the number of the first user variables to be initialized for a beam. It must be less or equal to the total number of internal variables used in a user type law (NUVAR).
  4. The initial state for beams may be defined by more than one block.
