getSolRatioVarUnit()
Return the SI unit of the "Solution Ratio" variable.
Usage
solRatioVarUnit = adb.getSolRatioVarUnit( name )
name (string)
The "Solution Ratio" variable name.
Return Value
solRatioVarUnit (string)
The SI unit of the variable.
name must be a valid name.
This routine returns the SI unit of the "Solution Ratio" variable. The "Solution Ratio" name is given by name. For example,
solRatioVarUnit = adb.getSolRatioVarUnit( 'pressure' )
