getResRatioValues()
Return the "Residual Ratio" values.
Usage
resRatioValues = adb.getResRatioValues( var, type = 'all', unit = None )
var (string) or (integer)
The "Residual Ratio" variable name/index.
type (string)
The type value; 'all', 'initial' and 'final'.
unit (string)
The "Residual Ratio" variable unit.
Return Value
resRatioValues (numarray)
The "Residual Ratio" values.
var must be a valid name or index.
type must be 'all', 'initial' or 'final'.
This routine returns the "Residual Ratio" values. The "Residual Ratio" name or index is given by var. For example,
resRatioValues = adb.getResRatioValues( 'velocity' )
