getOeiVarUnit()
Return the EI unit (default unit of unit category) of adb variable.
Usage
oeiVarUnit = adb.getOeiVarUnit( name )
name (integer) or (string)
Name or ID of an OEI name.
Return Value
oeiVarUnit (list) or (string)
The EI unit (default unit of unit category) of adb variable.
This routine returns the EI unit (default unit of unit category) of adb variable. This function needs an index as argument which is given by name. For example,
oeiVarUnit = adb.getOeiVarUnit( "wall" )
