getResRatioVarUnit()
Return the SI unit of the "Residual Ratio" variable.
Usage
resRatioVarUnit = adb.getResRatioVarUnit( name )
name (string)
The "Residual Ratio" variable name.
Return Value
resRatioVarUnit (string)
The SI unit of the variable.
name must be a valid name.
This routine returns the SI unit of the "Residual Ratio" variable. The "Residual Ratio" name is given by name. For example,
resRatioVarUnit = adb.getResRatioVarUnit( 'velocity' )
