getOfcValues()
Return the list of OFC integrated values.
Usage
ofcVals = adb.getOfcValues( name, var, unit = None )
name (integer) or (string)
Name or ID of an OFC name.
var (integer) or (string)
Name or ID of an OFC variable.
unit (string)
If unit is not None, the value will be converted to the new unit and be returned.
Return Value
ofcVals (list)
List of OFC integrated values.
This routine returns the list of OFC integrated values. This function needs two indices as argument which are given by name and var. If unit is not None, the value will be converted to the new unit and be returned. For example,
trac = adb.getOfcValues( "wall", "traction", "N" )
