getOsiValues()
Return the list of OSI integrated values.
Usage
osiVals = adb.getOsiValues( name, var, unit = None )
name (integer) or (string)
Name or ID of an OSI name.
var (integer) or (string)
Name or ID of an OSI variable.
unit (string)
If unit is not None, the value will be converted to the new unit and be returned.
Return Value
osiTimes (list)
List of OSI run times.
This routine returns the list of OSI integrated values. This function needs two indices as argument which are given by name and var. If unit is not None, the value will be converted to the new unit and be returned. For example,
trac = adb.getOsiValues( "wall", "traction", "N" )
