getSolRatioValues()
Return the "Solution Ratio" values.
Usage
solRatioValues = adb.getSolRatioValues( var, type = 'all', unit = None )
var (string) or (integer)
The "Solution Ratio" variable name/index.
type (string)
The type value; 'all', 'initial' and 'final'.
unit (string)
The "Solution Ratio" variable unit.
Return Value
solRatioValues (numarray)
The "Solution Ratio" values.
var must be a valid name or index.
type must be 'all', 'initial' or 'final'.
This routine returns the "Solution Ratio" values. The "Solution Ratio" name or index is given by var. For example,
solRatioValues = adb.getSolRatioValues( 'pressure' )
