getOsiVarUnit()
Return the SI unit (default unit of unit category) of adb variable.
Usage
osiVarNames = adb.getOsiVarNames( )
name (integer) or (string)
Name or ID of an OSI name.
Return Value
osiVarUnit (list) or (string)
The SI unit (default unit of unit category) of adb variable.
This routine returns the SI unit (default unit of unit category) of adb variable. This function needs an index as argument which is given by name. For example,
osiVarUnit = adb.getOsiVarUnit( "wall" )
