getOeiValues()
Return the list of OEI integrated values.
Usage
oeiVals = adb.getOeiValues( name, var, unit = None )
name (integer) or (string)
Name or ID of an OEI name.
var (integer) or (string)
Name or ID of an OEI variable.
unit (string)
If unit is not None, the value will be converted to the new unit and be returned.
Return Value
oeiVals (list)
List of OEI integrated values.
This routine returns the list of OEI integrated values. This function needs two indices as argument which are given by name and var. If unit is not None, the value will be converted to the new unit and be returned. For example,
trac = adb.getOeiValues( "wall", "traction", "N" )
