HM_ExtAPI::ReleaseGeomCurve()
Releases the handle to temporary curve.
bool ReleaseGeomCurve(
const HM_EntityGeometryCurve& curve
HyperMesh Ext API Function
The function ReleaseGeomCurve must be used to release the handle to temporarily created during the call to some of API functions curve object.
If the function succeeds, the return value is true. If the function fails, the return value is false. To get extended value information, call HM_ExtAPI::GetLastErrorCode().
Requires including hm_extapi.h.
curve
[in] - Handle to curve object that was returned by previous calls to API functions.
None.
