HM_ExtAPI::GeomSolidGetComponent()
Returns component the contains the solid.
bool GeomSolidGetComponent(
const HM_EntityGeomSolid & solid,
HM_EntityComponent& comp
HyperMesh Ext API Function
If the function succeeds, the return value is true. If the function fails, the return value is false. To get extended value information, call HM_ExtAPI::GetLastErrorCode().
Requires including hm_extapi.h.
solid
[in] - Handle to solid object that was returned by previous calls to API functions.
comp
[out] - The handle to the component. The value of the handle is NULL if the solid handle is invalid.
None.
