Explore, organize and manage your personal data, collaborate in teams, and connect to other data sources, such as
corporate PLM systems to access CAD data or publish simulation data.
Returns the transformation matrix between the global model coordinate system and the original local system of the model
part represented by the model assembly hierarchy document.
HM_ExtAPI::CADDocumentGetFileName()
Returns the complete path to the CAD model file, from which the model assembly hierarchy document was imported.
HM_ExtAPI::CADDocumentGetFirstChild()
Returns the first child of the document in the model assembly hierarchy of the CAD model loaded into the database.
HM_ExtAPI::CADDocumentGetLinkName()
Returns the name of the link used as a reference to the model assembly hierarchy document in the assembly hierarchy tree.
HM_ExtAPI::CADDocumentGetLocalSystem()
Returns the transformation matrix between the global model coordinate system and the original local system of the model part represented by the model assembly hierarchy document.
HM_ExtAPI::GenerateMesh()
Generates a mesh on surfaces of the model loaded into the HyperMesh database, using mesh areas and constraint edges and points.
HM_ExtAPI::GetRootCADDocument()
Returns the root document in the model assembly hierarchy of the CAD model loaded into HyperMesh database.
HM_ExtAPI::GetRootCADDocumentsCount()
Returns the number of root documents in the model assembly hierarchy for each CAD model loaded into HyperMesh database.
HM_ExtAPI::SetScratchFolder()
Turns on or off generation of log files by different components used within HyperMesh, and sets the folder to redirect output of these files.
