HM_ExtAPI::LoadModel()
Loads model from HyperMesh file into HyperMesh database.
bool LoadModel(
const char*  model_file_path
HyperMesh Ext API Function
If the function succeeds, the return value is true. If the function fails, the return value is false. To get extended value information, call HM_ExtAPI::GetLastErrorCode().
Requires including hm_extapi.h.
model_file_path
[in] - Model file name.
None.
