HM_ExtAPI::DeleteModel()
Deletes model from HyperMesh database.
bool DeleteModel(void);
HyperMesh Ext API Function
If the function succeeds, the return value is true. If the function fails, the return value is false. To get extended value information, call HM_ExtAPI::GetLastErrorCode().
Requires including hm_extapi.h.
None.
