HM_ExtAPI::MeshGetFirstElement()
Returns the first element in a mesh referenced by a mesh object.
bool MeshGetFirstElement(
const HM_EntityMesh& hmesh,
HM_EntityElement & helem
HyperMesh Ext API Function
This is used together with the function HM_ExtAPI::MeshGetNextElement() to iterate through all the elements contained in the mesh referenced by the mesh object. The call to HM_ExtAPI::MeshGetFirstElement() resets internal element counter of the mesh object to the first element. The following calls to HM_ExtAPI::MeshGetNextElement() increment the counter until all elements are iterated.
If the function succeeds, the return value is true. If the function fails, the return value is false. To get extended value information, call HM_ExtAPI::GetLastErrorCode().
Requires including hm_extapi.h.
hmesh
[in] - Handle to mesh object that was returned by previous calls to API functions.
helem
[out] - Handle to the first element in the mesh referenced by mesh object. The value of the handle is zero in case the mesh does not have elements.
None.
