Explore, organize and manage your personal data, collaborate in teams, and connect to other data sources, such as
corporate PLM systems to access CAD data or publish simulation data.
Contains information that is used by the HM_ExtAPI::OffsetFaces() and HM_ExtAPI::OffsetShellsByFaces() functions to set offset parameters and return offset results.
HM_BatchMeshParamSet
Contains a pair of paths to batch mesh parameter and criteria files used by HM_ExtAPI::GenerateMesh.
HM_Component
Contains information about an individual component in the topology of mesh areas defined by the HM_Topology structure.
HM_Edge
Contains information about an individual edge in the topology of mesh areas defined by the HM_Topology structure.
HM_Face
Contains information about an individual face in the topology of mesh areas defined by the HM_Topology structure.
HM_FaceLoop
Contains information about individual face loops in the topology of mesh areas defined by the HM_Topology structure.
HM_GenerateMeshParamStruct
Contains information that is used by the HM_ExtAPI::GenerateMesh() function to set meshing parameters in interactive and batch meshing modes.
HM_ImportModelParamStruct
Contains information that is used by the HM_ExtAPI::ImportModel() function to set import parameters.
HM_OffsetParamStruct
HM_Point
Contains information about a point in three-dimensional space.
HM_PolyLine
Contains information about the geometry of a line represented by approximation points.
HM_Topology
Contains information about mesh area topologies that includes a set of faces, edges and vertices and topological relations between them.
HM_Transform
Contains information about a transformation between different coordinate systems.
HM_Vertex
Contains information about an individual vertex in the topology of mesh areas defined by the HM_Topology structure.
