HM_BatchMeshParamSet
Contains a pair of paths to batch mesh parameter and criteria files used by HM_ExtAPI::GenerateMesh.
struct HM_BatchMeshParamSet {
const char* param_file_path;
const char* criteria_file_path;
HyperMesh Ext API Function
Contains a pair of paths to batch mesh parameter and criteria files used by HM_ExtAPI::GenerateMesh. These set the individual parameters and criteria for specified topology faces or components. This structure is used only in batch mesh mode.
The structure information is declared in hm_extapi.h.
The members are: param_file_path and criteria_file_path
param_file_path
The path of the text file containing the meshing parameters.
criteria_file_path
The path of the text file containing the meshing criteria.
None.
Version History
11.0.101
