HM_ExtAPI::GeomFaceAddFixedPoint()
Adds fixed point to existing face.
bool GeomFaceAddFixedPoint(
const HM_EntityGeomFace& face,
double u,
double v,
HM_EntityGeomVertex* new_fixed_point
HyperMesh Ext API Function
If the function succeeds, the return value is true. If the function fails, the return value is false. To get extended value information, call HM_ExtAPI::GetLastErrorCode().
Requires including hm_extapi.h.
face
[in] - Handle to face object that was returned by previous calls to API function.
u
[in] - U parameter of the fixed point.
v
[in] - V parameter of the fixed point.
new_fixed_point
[out] - If not NULL then returns handle to the new fixed point.
None.
