HM_ExtAPI::ComponentGetNextFreeGeomPoint()
Returns the next free point of the component.
bool ComponentGetNextFreeGeomPoint(
const HM_EntityComponent& comp,
HM_EntityGeomVertex& fpoint
HyperMesh Ext API Function
The function ComponentGetNextFreeGeomPoint is used together with the function HM_ExtAPI::ComponentGetFirstFreeGeomPoint() to iterate through all free points contained in the component. The call to ComponentGetFirstFreeGeomPoint resets internal component counter to the first point. The following calls to ComponentGetNextFreeGeomPoint increment the counter until all free points of the component are iterated.
If the function succeeds, the return value is true. If the function fails, the return value is false. To get extended value information, call HM_ExtAPI::GetLastErrorCode().
Requires including hm_extapi.h.
comp
[in] - Handle to component object that was returned by previous calls to API functions.
fpnt
[out] - Handle to the next free line of the component. The value of the handle is zero in case if component does not contain free lines or if all free lines were already returned by previous calls to ComponentGetFirstFreeGeomLine and ComponentGetNextFreeGeomLine.
None.
