HM_ExtAPI::MemoryAlloc()
Allocates memory block of specified size.
void* MemoryAlloc(
unsigned int byte_size
HyperMesh Ext API Function
The function HM_ExtAPI::MemoryFree() must be used to release the memory allocated within the call to MemoryAlloc function.
If the function succeeds, the return value is the pointer to allocated memory block. If the function fails, the return value is NULL. To get extended error information, call HM_ExtAPI::GetLastErrorCode().
Requires including hm_extapi.h.
byte_size
[in] - The size of allocated memory block.
None.
