HM_ExtAPI::CreateFreeGeomPoint()
Creates new free point in the HyperMesh database.
bool CreateFreeGeomPoint(
HM_EntityGeomVertext& new_point,
const HM_Point& point3d,
HM_EntityComponent comp
HyperMesh Ext API Function
If the function succeeds, the return value is true. If the function fails, the return value is false. To get extended value information, call HM_ExtAPI::GetLastErrorCode().
Requires including hm_extapi.h.
new_point
[out] - Handle to new free point object.
point3d
[in] - Point coordinates.
comp
[in] - If not NULL then components where the point is created. If NULL then the point is created in current component.
None.
