/INISHE/EPSP or /INISH3/EPSP
Block Format Keyword Describes the initial plastic strain for a shell.
/INISHE/EPSP/unit_ID or
/INISH3/EPSP/unit_ID
shell_ID   ε p
unit_ID Unit Identifier
(Integer, maximum 10 digits)
shell_ID Element identifier
(Integer)
ε p Plastic strain
(Real)
  1. If the shell property uses several integration points, the given plastic strain value is set to each integration point.
