/GAUGE/SPH
Block Format Keyword Defines SPH gauges.
/GAUGE/SPH/gauge_ID/unit_ID
gauge_title
node_ID     Fcut shell_ID DIST
gauge_ID Gauge identifier
(Integer, maximum 10 digits)
unit_ID Unit Identifier
gauge_title Gauge title
node_ID Node identifier
(Integer)
Fcut Cutoff frequency
(Real)
[Hz]
shell_ID Shell identifier. Only 4-node shells can be used.
(Integer)
DIST Distance between gauge and shell surface
> 0
Gauge in the side pointed by normal of shell surface.
< 0
Gauge in the opposite side of the normal of shell surface.
Default = 0 (Real)
[ m ]
  1. SPH pressure gauges can be defined by:
    • A node using a node identifier (node_ID > 0), or
    • A shell element (shell_ID) and a distance (DIST). In this case node_ID must be equal to 0.
  2. The SPH approximation is used for measuring the pressure (density) at the gauge location:(1)
    π ( x ) = i , p a r t i c l e s P i V i W ( x x i , h i )
    with x i , h i , V , and P i , respectively being the location, diameter, volume, and the pressure of particle i .
    A correction at order 0 applies in the above equation, whatever the correction order which are specified into the SPH properties.
  3. The pressure may be filtered (a 4-pole Butterworth filter is used).
  4. SPH pressure gauges and ALE or FVM gauges (/GAUGE) cannot share the same gauge_ID.
