The solid to SPH option (Sol2SPH) enables you to turn a solid element into particles in order to increase the time
step/robustness of a Lagrangian calculation, while not significantly changing the physics.
Optimization in Radioss was introduced in version 13.0. It is implemented by invoking the optimization capabilities of
OptiStruct and simultaneously using the Radioss solver for analysis.
The particles should be created in a hexagonal compact, face centered cubic or a
cubic net packing.
The hexagonal compact net and face centered cubic are recommended for use in
Radioss and give similar results. A face center
cubic particle distribution can be created using the HyperMesh SPH panel. A HyperMeshTcl macro to generate hexagonal compact net is
available from the Altair Connect website.
Hexagonal Compact Net
A cubic centered faces net realizes a hexagonal compact distribution, which can be useful to
build the net.
The hexagonal compact net distribution can be created in HyperMesh using a Tcl script
available by searching in Altair Connect for the
Hexagonal Compact Net Tcl script. When using this
script, the pitch or distance between any particle and its closest neighbor is
entered as h0.
The mass of the particle mp is defined in the property
/PROP/SPH.
The SPH particle mass relates to the material density
and the pitch h0 of the hexagonal compact net. This particle mass can be
calculated as:(1)
Since the space can be partitioned into polyhedras surrounding each particle of the net, each one
with a volume:(2)
Due to discretization differences in the volume, the mass can be more accurately
represented by:(3)
Where,
Total volume filled by the particles.
Total number of particles distributed in the volume.
For hexagonal compact net, the recommended smoothing length h in
/PROP/SPH is the pitch h0 which is the smallest distance between the particles. A smoothing length smaller
than is this can only be used when there is no tension physical problems material.
If the material does include tensile behavior, then a smoothing length larger than
h0 can be used to increase stability but there will be an increase in the
computational cost.
The following table shows the number of neighbors with when different smoothing
lengths h in /PROP/SPH are used. The accuracy
and computational cost of the simulation improves as the smooth length
increases.
Table 1. Number of Neighbors in a Hexagonal Compact Net
Distance
d
Number of
particles at distance d
Number of
particles within distance d
h0
12
12
6
18
24
42
2h0
12
54
24
78
Face Centered Cubic
The face centered cubic arranges the particles in groups of 14, forming the corners
and the center of each face of a cube.
Similar to hexagonal compact net, each particle has 12 neighbors and the mass of a
particle is:(4)
For face centered cubic the recommended smoothing length h in
/PROP/SPH is the pitch entered when created the sph mesh in
HyperMesh. The pitch h0 is the smallest distance between the particles. A smoothing length smaller than
h0 can only be used when there is no tension physical problems material. If the
material does include tensile behavior, then a smoothing length larger than h0 can be used to increase stability but there will be an increase in the
computational cost.
Simple Cubic Net
Let, c the side length of each elementary cube into the net.
The mass of the particles mp should relate to the density of the material
and to the size c of the net, with respect to the following equation:(5)
Table 2. Number of Neighbors in a Cubic Net
Distance d
Number of particles
at distance d
Number of particles
within distance d
c
6
6
12
18
8
26
2c
6
32
24
56
24
80
12
92
3c
6
98
From experience using cubic net, a higher smoothing length compared to face centered
cubic or hexagonal compact net is needed to solve the tension instability. This
higher smoothing length increases the computational cost since more neighbor
particles have to be included in the calculation for each particle.
For cubic net, a smoothing length h between 1.25c and 1.5c is
recommended in /PROP/SPH.
