Design Optimization
Optimization in Radioss was introduced in version 13.0. It is implemented by invoking the optimization capabilities of OptiStruct and simultaneously using the Radioss solver for analysis.
Optimization in Radioss provides Radioss users an easy way to set up optimization problems, and take advantage of optimization solutions in OptiStruct. The equivalent static load method (ESLM) is used to perform the optimization run.
