2021
View new features for Radioss 2021.
The Radioss solver can be executed using different methods described here.
The Smooth Particle Hydrodynamics method formulation is used to solve the equations of mechanics, when particles are free from a meshing grid.
Optimization in Radioss was introduced in version 13.0. It is implemented by invoking the optimization capabilities of OptiStruct and simultaneously using the Radioss solver for analysis.
This manual describes the interface between Altair Radioss and a user’s subroutines.
