Arbitrary Lagrangian-Eulerian (ALE) and Computational Fluid Dynamics (CFD)
With Arbitrary Lagrangian-Eulerian (ALE) and Computational Fluid Dynamics (CFD) Simulation, the following phenomena can be modeled:
  • Transient Analysis
  • Laminar and turbulent flow ( k ε model, LES Smagorinsky)
  • Compressible and semi-incompressible flow
  • Conductive heat transfer
  • Fluid/structure coupling
  • Multi-material
The most used fields of application are:
  • Classical fluid flow analysis
    • Internal flows
    • Aerodynamics
    • Free surface
    • Open channel with obstacles
    • High speed tooling
  • Fluid/structure interaction
    • Valves
    • Exhaust noise source prediction
    • Laser welding
    • Nuclear accidents
    • Defense
