Elementary Boundary Conditions
- Imposed varying conditions according to user function
- Continuity
- Smoothly varying predefined function
Non-reflective frontiers (NRF) (Material 11, option 3) ensure free field impedance to pressure and velocity fields.
With Radioss ALE/CFD any combination of the above options can be specified; on the counterpart, the closure of the various convection and diffusion equations has to be verified carefully by you.
- Inlet, flux is imposed using imposed velocities; density, energy, turbulent energy (that is: k) are imposed as constants. Continuity is imposed for pressure (display purposes only) and for epsilon. Turbulent energy, rho k is set to zero for external flows and to 1.5*rho*(0.06 Vin)^2 for internal flows.
- Outlet, continuity for all variables except pressure, which is imposed. When using the Non-reflective frontiers (NRF) option, you provide a value for sound speed and a typical relaxation length, which must be greater than the largest wave length of interest.
- Sides, continuity for all variables with the Non-reflective frontiers (NRF) option or slip conditions without boundary elements.
If an element does not exist at boundary, continuity is assumed; but kinematic conditions are necessary to disallow fluxes; otherwise the convection equation is not closed and the program can diverge.
